I use Vegas Pro 10.0, and would like to change the default settings in the transitions (e.g., fade through black) to make them shorter. I can't figure out where to do this. I was thinking that the solution might be to create a new transition with the settings I want, but can't figure out how to do this either.
Also, since I use a limited number of preset transitions and media generators, I would like the display to show only the ones I use, instead of having to scroll through a vast number of options. Does anybody out there know if this is possible?
Thanks!
Results 1 to 1 of 1
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
Default settings in Vegas Pro 10.0
By TKB in forum EditingReplies: 5Last Post: 20th Jun 2011, 10:06 -
Changing default video renderer
By deadgamer in forum Software PlayingReplies: 0Last Post: 3rd Jul 2010, 07:02 -
Changing DeVeDe default settings
By henrik.uggla in forum LinuxReplies: 0Last Post: 25th Jun 2007, 13:29 -
Changing Vegas' Default Media Library Location
By ShBm in forum EditingReplies: 0Last Post: 9th Jun 2007, 13:22
