  1. I try to rip toy story2 and noted that the scenes repeat 3 times after intervals of time. I guess that is a kind of proctetion (?) Is there some
    way to solve this problem??
    Jose Eduardo
  2. Why is it some kind of 'protection' ? People always say that....
    Your 'problem' is because you are ripping the title incorrectly. It's a seamless branching/multi-angle movie, hence the repeating scenes. You need a ripper, or need to rip it using IFO parsing. Use cladDVD XP and select the required ProGram Chain (PGC) and all will be OK.
  3. I have the same problem with the same DVD, Toy Story 1 and 2.
    I tried to rip it with DVD Decrypter and the vob files copied to my harddrive was doing the problem so i knew it was the ripper i used.
    I am gonna do A SVCD out of it and I use DVD2SVCD so I just let the Internal Routines of DVD2SVCD do it for me and gave me no problems.
    Try different ripper like CladDVD since it is based on VStrip
  4. Originally Posted by dlgrande
    Jose Eduardo
    NO Fool
    It's repeated for each language.
    2 ways round it. Try cladmec to rip it. It should rip the vobs as they are to be viewed.
    2nd method Rip the DISC including ifos and use old program dvd2mpg squeezer also how to do matrix
    have fun
    Surprised the great shizzon never told you
  5. naw....
    the only problem with dvddecryptor is that on default it is NOT set to remove multi-angles
    so here's wut u do, goto "options" and click on MULTI-ANGLE PROCESSING...
