Hello and thank you in advance for your help.
I have a direct DV file captured from my MiniDV camcorder using WinDV, it's 13GB and plays nicely in all players, my system is Win 7 64bit. I used to use DvDate before but now it's giving me this message:
Video not available. The file xxx seems not to be a correct AVI file.
Is anything missing? is there a better way to embed the date-code on to a DV file for free?
Sincerely yours.
Shyrah.
Try some other tools and see if they find the datecode, DV Sub Maker, dv_datecode, etc.
Baldrick, thank you very much for your answer, however both those progrmas make a srt file and do not EMBED the dare into the video like DvDate does.
I searched around and found another user with the same problem and he solved it by following this advice below which I do not understand at all:
"It's Haali splitter. Needs to deselect AVI "
Do you have any ideal what this means?
Thanks again. -
Do you have haali media splitter installed? Then you could try uninstall it. Or reinstall it and disable avi in the configuration.
Thanks again Baldrick, I uninstalled it and still no use, But I've managed to solve the problem by transferring the video to another PC with a 32 bit win 7 and the DVDate program worked perfectly, so I guess it's just not working in 64 bit win 7.
I appreciate your time.
Shyrah.
mts file datecode
By mpegjohn in forum ProgrammingReplies: 3Last Post: 7th Jan 2012, 09:48 -
Samsung S10 HD Camcorder - Getting mp4 files with time / date stamp added
By time2innov8 in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2011, 06:06 -
inlay datecode on AVCHD
By jjblackisback in forum Video ConversionReplies: 10Last Post: 4th Apr 2011, 14:44 -
Capturing Time-Stamp/Date-Stamp to video
By EnjoyLife in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 4th Apr 2009, 13:48 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
