I am running a PVR-150 in a windows 7 64 bit machine with Win TV6 to try and do some VHS->DV captures.
Having a problem in that the Hue and Saturation controls are not working as expected.
Brightness and Contrast sliders go from 0 to 255 and operate as expected.
Hue and Saturation also have sliders form 0 to 255 but are acting like switches.
With Saturation at 0 the picture is black and white. With the slider at 1, the picture is slightly oversaturation. With the slider form 2-255 there are no changes from the slider at 1.
Similarly with Hue, 0 is a slightly red/sunburned look. 1-255 All looks exactly identical with a slight Green tint.
Any ideas what is going on?
Spektre
What software you capturing with? I would try using Graph Studio to change the video proc amp settings while the other program is capturing ore previewing. Start the capture program. Start Graph Studio. In Graph Studio add the filter that has the PVR-150's video proc amp settings. That's usually a crossbar or capture filter. It will have a name something like "Hauppage PVR-150 capture filter". After adding the filter to the graph right click on it and select Properties. Go to the proc amp tab and adjust the sliders. With most capture devices you'll see the picture change dynamically as you move the sliders in Graph Studio. The values that appear in Graph Studio are often different than the values that appear in the capture program. That could be the source of the problem you're having.
Thanks, I'll try Graph Studio.
I am using Win TV6. It has a ProcAmp section to adjust the values, but instead of being continuous, they are operating like switch on or off.
Spektre -
I know what you are saying about the proc amp. I'm telling you another way to set the proc amp that may work better. Or it may not. But it's worth a shot.
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 18:11 -
Need help connecting Hauppauge 150 PVR from TV/VCR set up
By magicfingers in forum Capturing and VCRReplies: 17Last Post: 5th Sep 2008, 06:41 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 10:03 -
hauppauge pvr 150: Need REAL software to record
By SignedupGuest in forum Capturing and VCRReplies: 16Last Post: 19th Feb 2008, 12:40 -
Hauppauge WinTV PVR-150 ($60) vs. ATI TV Tuner 650 ($100)
By RoganSarine in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2007, 02:48
