Results 1 to 9 of 9
    Jan 2011
    poland
    Hello,
    my original input is h264 from HD PVR (1080i) and after passing simple script to x264.exe I got different fps while encodig:
    directShowSource - about 40 fps
    ffVideoSource - about 25 fps
    avcSource - 20 fps
    I would stay with DSsource (the fastest) but x264.exe gives an warning message that converts from yuy2 to yv12 - (so it means that conversion is done twice - first by avisynth from yv12 to yuy2 and then by x264 from yuy2 to yv12 - these are my own observations as I'm not familiarized with that subject
    Is there other way to get the speed of dsSource or to make dsSource not convert to yuy2?
    Thanks.
    Jul 2009
    Spain
    Try using DirectShowSource(pixel_type="YV12").
    Jan 2011
    poland
    Hi,
    when I use this switch I got an error "filter graph manager won't talk to me"
  4. what directshow decoder are you using ?
    render the file in graphstudio if you don't know
    did you try ffms-mt (the multithreaded version of ffvideosource) ?
    Jan 2011
    poland
    1. from graphStudio: my.ts --- microsoft DTV-DVD Video Decoder --- video renderer
    2. dont know which one it is I'm using - just copied ffms2.dll to avisynth's plugins directory (and by the way after using it - ffms2- the video playback is corrupted - frames are mixed while playing avs script in player or in vdub - the only solution is to "reset" playback by rewind button on the player - then everything goes smooth"
    edit:
    ad 1. -when I open avs script in graph studio then i get:
    my.avs --- color space converter --- video renderer <-- when pixel_type is set to yv12
    and
    my.avs --- avi decompressor --- video renderer <-- when pixel_type is not used
  6. use preferred filter tweaker to disable the microsoft decoder , install ffdshow, haali media splitter
    in ffdshow, set avc/h.264 to ffmpeg-mt
    render the file again in graphstudio to see if you you've set it up properly
    ffms2 (either version) is not that reliable for transport streams, especially interlaced avc
    Jan 2011
    poland
    I disabled microsoft decoder and set avc/h.264 to ffmpeg-mt in ffdshow.
    I followed your sugestions and now directShowSource is working without any color conversion.
    But now graph studio is showing coreAVC (as I purchased this one before) - I think if I disable this one then I'll get fdshow working - anyway the case is solved - thank you.
  8. Originally Posted by adom View Post
    Hello,
    avcSource - 20 fps
    Have you ever noticed that different InputSorce filters report different counts for total number of frames for same input video source?
    Jan 2011
    poland
    i'm not quite sure what you mean - but same video via directShow shows 7089 frames and with ffms2 shows 7090 frames.
