I have seen several youtube videos where people have added 3d text, or just plain text to the video that moves with the items in the scene. Like the effect they used in zombie land? what is this effect called and what software can you use to recreate this easily?
It's called 3d matchmoving , or 3d compositing
It involves motion tracking and "solving a 3d scene" by calculating motion vectors; so you can place objects (e.g. 3d text) into a scene, as if they existed there when you were shooting.
There is no "easy software" for this, at least not if you want semi decent quality
Typical software used for the matchmoving part: PF Track, syntheyes, foundry camera tracker , nuke, boujou, maya etc... Most of them are very expensive
A free one is voodoo, but I don't know how well it works
http://www.digilab.uni-hannover.de/docs/manual.html
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 16:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
