Dear all!
Last month, I downloaded Mozart: Magic Flute from TPB ... and it was a VIDEO_TS folder with so many VOB files in it.
Now, in order to save some space in my HDD, I wish to convert it to MKV(AVC) or H264 ... because some said H264's better.
Firstly, I used FormatFactory and reduce the original bitrate in a half.
*** Example: Original: 5000kbps ... I reduced it to 2400kbps.
But the picture's sharpness is drastically decrease.
So I set the bitrate to default. But the decrease remains drastically. So I googling and asking people. They recommend me to used Avidemux and Handbrake and give Pavtube a try ... but the result is the same.
So I back to FormatFactory and set the Video Size to 50% ... and the decreased are disappeared. But the new problem comes ... there is a black area within the display's Right-Left-Above-Below.
Why? Somebody please guide me ...
Thanx.
Sorry for my english ... hope everybody are able to understand what I mean.
Thank you.
Results 1 to 10 of 10
Follow a guide, click on handbrake and scroll down to guides or http://www.dvd-guides.com/guides/dvdrip/235-convert-dvd-to-h264-mkv-mp4-using-handbrake
Thread moved to video conversion.
as suggested by baldrick HandBrake or XMedia Recode will definitely serve your purpose.
go through relevant guides here on Video Help Guide Section.
Guide 1 : DVDs to high quality MP4 or MKV files - HandBrake by Baldrick
Guide 2 : Converting Blu-Ray to MKV using XMedia Recode may apply to DVD as well. -
HandBrake gonna produce high quality output if selected codec is configured properly as compared to XMedia Recode which has poor bitrate control.
.264 file extension. Can't convert using h264 methods.
By firebirdude in forum Video ConversionReplies: 44Last Post: 19th Sep 2016, 09:02 -
convert a .h264 TS file to something my XBOX360 can play
By manikm in forum Video ConversionReplies: 1Last Post: 25th Nov 2009, 15:48 -
Convert FLV-file with H264 format into xvid?
By mccm in forum Video ConversionReplies: 2Last Post: 8th Oct 2009, 12:54 -
How to convert a H264 TS File to XviD
By onesikgypo in forum Video ConversionReplies: 9Last Post: 6th Aug 2009, 15:15 -
.ts file convert to h264/aac with hardcoded subtitles
By akiraku in forum Video ConversionReplies: 4Last Post: 25th Apr 2009, 09:49
