Hello,
If I add a filter to a video in avidemux (MPlayer delogo), and I delete the original video but keep the altered video. Can I somehow remove the MPlayer delogo filter of the altered version in order to recreate the original? Or possibly toy with some settings in order to partially recreate the original or somehow make what was there slightly more visible? Whether in avidemux or any other program out there.
I used the MPlayer delogo filter in avidemux to "wipe out" the textchat area of a video i've made, as cropping it would remove a significant portion of the video and avidemux cannot blur or blacken a portion.
Can the text area, or whatever is underneath the MPlayer delogo filter be recreated or made to be slightly visible, whether with avidemux or any other program?
It must be a joke
Maybe some "data recovery" software could help you to "undelete" the original video file.
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 11:26 -
Any way to determine is something was altered?
By droidgrl10 in forum Newbie / General discussionsReplies: 2Last Post: 19th Apr 2012, 09:49 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07 -
can a recording be altered
By blackbird11 in forum AudioReplies: 6Last Post: 22nd Nov 2009, 09:44 -
Removing hardsubs with Avidemux?
By Haraiso in forum EditingReplies: 6Last Post: 18th Oct 2009, 01:40
