Hi,
I had purchased a home theater with DivX & MPEG-4 support (H.264). Now I am planning to buy a camera which records HD movies in .MOV format. I believe .MOV format is the basis for .mp4 formats as mentioned on the wikipedia. Would my DVD player be able to run these movies in .MOV format or I would require to convert them first.
If I do not want to alter the video & audio format, what is the best way to change the containers.
Regards.
Probably not. But you you might be able to change the mov to mp4 without video reconversion using a mp4 multiplexer(yamb, mymp4boxgui, avidemux, ffmpeg).
And please tell us the name of the home theatre player. Some might have more info then. -
Note that if you purchased a DVD player in this system and not a BluRay player that DVD players almost never are able to play back other supported formats like Divx in high definition. So while a remuxed MOV file turned into MP4 might play if it's in standard definition, it probably won't play if it's a remuxed high definition file.
Thanks for the responses.
I have a Sony home theatre DAV TZ200. It does play HD video but as I see in the user manual, there are limitations on the file size (2GB).
I expect multiplexing without video reconversion would not be a heavy process. I have an old PC P4 2.6Hgz with 512Mb RAM. Are there any hopes for it to be useful for the purpose? I would primarily require it to convert some home HD videos of 30-40 min length max.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Windows Media Player stopped playing .mov files
By dzsoul in forum Software PlayingReplies: 2Last Post: 19th Mar 2009, 00:29 -
Newbie question on mov files and how to watch on Dvd player
By helper in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2008, 08:01 -
Problem playing a .mov file with Media Player Classic - No audio
By shiningwizard in forum Software PlayingReplies: 4Last Post: 20th Sep 2008, 07:52 -
.mov not playing on laptop (qt alternative 1.90)
By Browncoat in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2007, 14:02
