I use Vegas Pro 10.0, and would like to change the default settings in the transitions (e.g., fade through black) to make them shorter. I can't figure out where to do this. I was thinking that the solution might be to create a new transition with the settings I want, but can't figure out how to do this either.
Also, since I use a limited number of preset transitions and media generators, I would like the display to show only the ones I use, instead of having to scroll through a vast number of options. Does anybody out there know if this is possible?
Thanks!
The length of a transition is determined by the length of your fade/crossfade. You can set a default time in preferences. Example, I use .5 (half second) and the cursor will snap on that.
To set any transition as a preset, open the "animate" timeline and set the length with keyframes, then save and it will become one of the presets. -
Thanks. I tried it, and for some reason, it didn't work. I also tried creating a new preset with the fade/crossfade I want, and now I have a preset with the name I gave it, but with the same default setting the old one had.
Any ideas on why it's not working? -
Hmmm....it seems to only save whatever settings you use to start the transition.
There are other ways to do this, but before I go off on that, it may be possible to use automation or scripting, although I never use that, so I can't advise anything.
You might bring this up in the Vegas forum.
Come back here if you want to do it manually, as a prebuilt event that you can composite. -
Go to the "Media Generator" tab, choose the solid color black, drag to the timeline, then make it the length you want.
Right-click on the track and insert a composite envelope. Make two points around the black box, and make your fade.
Make a selection of your new fade and render it to "Still Image Sequence", PNG format into a new folder.
Bring it into Vegas pre-animated, by clicking the first file, then "Open Image Sequence" check box on the open dialog.
EDIT: just noticed you wanted "fade THROUGH black", not fade to. So just add another fade to the right side of the black box.Last edited by budwzr; 20th Jun 2011 at 16:50.
Vegas Pro proper render settings
By ingeborgdot in forum EditingReplies: 24Last Post: 20th Sep 2011, 16:01 -
HELP changing default settings in Vegas
By TKB in forum Newbie / General discussionsReplies: 0Last Post: 16th Jun 2011, 00:04 -
Sony Vegas Pro 9 Render Settings?
By Wickwire in forum Video Streaming DownloadingReplies: 8Last Post: 28th Dec 2009, 09:46 -
Best settings for vegas pro 8.1 and youtube.
By ingeborgdot in forum Video Streaming DownloadingReplies: 16Last Post: 27th Nov 2009, 19:50 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 16:32
