I've encoded a .ts file into .mkv format . The original audio was MPEG Audio . After encoding resulted a similar MPEG Audio track but out of sync.
I converted MPA into AC3 but same out of sync between sound and image..
How could I solve this issue ???
				Results 1 to 9 of 9
	Audio
 Menu ID : 1 (0x1)
 Format : MPEG Audio
 Format version : Version 1
 Format profile : Layer 2
 Codec ID : 4
 Duration : 1h 21mn
 Bit rate mode : Constant
 Bit rate : 256 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Compression mode : Lossy
 Delay relative to video : 100ms
 Stream size : 149 MiB (1%)
 and after encoding :
 Audio
 Format : MPEG Audio
 Codec ID : A_MPEG/L2
 Codec ID/Hint : MP2
 Duration : 1h 21mn
 Bit rate : 256 Kbps
 Language : English
 after converting with BeSweet :
 Audio
 Format : AC-3
 Format/Info : Audio Coding 3
 Muxing mode : Header stripping
 Codec ID : A_AC3
 Duration : 1h 21mn
 Bit rate : 384 Kbps
 Sampling rate : 44.1 KHz
 Bit depth : 16 bits
 Stream size : 223 MiB (2%)
 Language : English
	You didn't answer the question. Is it off by the same amount all the way through (easy to fix) or does it get worse the longer the video plays (much harder to fix)? My guess is that it's off by the same amount all the way through and you just have to delay the audio by the correct amount when muxing (or get rid of the delay entirely using DelayCut).
	There are other programs, yes, that can remove delays. If you know the amount of the delay, though, DelayCut can't be beat (as long as the audio is DVD Compliant, which MP2 audio is). Just figure out the amount of the delay, fill in that amount in the Delay->Start box, Process it, and use the 'fixed' audio when muxing.
	That's the problem  ( (
 I don't know the amount of delay and I don't know how to figure it out
	OK ,many , many thanks...let's see !!!!!
 I'll be back with ...good results , I hope
  Can you solve this puzzle?By tin2tin in forum Newbie / General discussionsReplies: 8Last Post: 15th Apr 2012, 23:54
  help the FBI solve a murderBy deadrats in forum Off topicReplies: 3Last Post: 10th Apr 2011, 01:38
  I have a strange problem and I would like to ask if is possible to be solveBy takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 15:53
  USING Nero TO SOLVE ALL BURNING PROBLEMS?By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18
  cannot detect file type ( no one can solve this 1)By nirbhayn in forum Software PlayingReplies: 11Last Post: 12th Jul 2007, 10:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
