Does anyone know what softs are necessary to convert a MPA file to AC3 ???
I've tried ImToo and BeSweet but cannot install them , or they require special methods for installing....
Maybe there is another soft..... The tutorials found here are from 2000
Thanks !
	Where(on your computer) did you put BesweetGUI ?BeSweet is an audio transcoding tool. It lets you convert audio files from one format to another. Command line tool but get the BeSweetGUI for a graphical interface.
	Solved
 I've also installed that .dll file that were misiing
	I have BeSweet installed in PROGRAMS on :c....and BeSweetGUI in almost the same place as you(in a folder on one of my storage internal drives). As long as
 BeSweetGUI is pointing at the BeSweet.exe file it should work perfectly.
	One of us should also report a broken link to BeSweetGUI here on Videohelp huh?
	Added the required dll to https://www.videohelp.com/download/BeSweetv1.5b31BeSweetGUIv0.7b4.zip
  How to convert WAV/MPA/MP3 audio to AC3(DD) using BesweetBy Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14
  How to convert WAV/MPA/MP3 to AC3 6 channels?By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 15:12
  Convert ac3 to mpaBy pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 13:39
  How do I convert an mpg file using AC3 to use MPA instead?By bmoret in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 10:19
  Mpa to ac3 5.1By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 19:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
