    Jan 2003
    India
    http://update.downloadhelper.net/index.html
    http://www.downloadhelper.net/screen-capture.php
    You need to enable screen capture in Download Helper preferences, and to download cs helper addon for windows.
    Once that is done in preferences under capture-screeen capture tab, you can select your video codec, and to record sound also, select record audio from speakers
    Should be useful for sites, where the only option to download is screen capture.
    Jun 2011
    White Bear Lake, MN
    Video downloadhelper 4.9.1 I get no audio on downloaded file. Why?
