This has surely been addressed before. I there a tool that permits time resyncs of audio to video in linear segments in an avi. This file must be damaged as it will not play on a divx player, but it will play with MPC. Passing it through XviD4PSP (video copy) makes it playable but the audio sync changes from time to time. Something similar to subtitle resync editing in SubtitleWorkshop would do the trick, is there such a beast?
Thanks.
Maybe this will do it.
http://www.squared5.com/svideo/mpeg-streamclip-win.html
Read "Requirements"
Once you get it to run, load the video and press 'Ctrl+F' (Edit/Fix Timecode Breaks)
Click File/Export or Convert or Demux
Cheers. -
If you have sync drifting in and out there is usually only one solution - cut the audio up into smaller and smaller chunks and align each chunk as you go along. For this you need to use an NLE like Vegas.
Before getting to that point I would suggest perhaps running it through one or more of the repair tools, or sourcing a better copy.Read my blog here.
I got to looking through this page https://www.videohelp.com/tools/sections/video-repair-fix and tried SyncView 2.01.01. It will not run, "Display Setting Not Supported Your Windows display (DPI) setting is not compatible with the software. Click OK to cancel the program (helpful!)". Searching does not seem to turn up any info on what this setting should be.
Any Ideas? -
Run the file through AviDemux and see if it is a "packed" file if it is let AviDemux fix it - shouldn't take more than a couple of minutes and doesn't re-encode.
If AviDemux identifies VBR and wants to rebuild the index then do that AND this time re-encode the audio with MP3 (Lame) rather than a stream copy.
Worth a trySONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Corrupted/damaged video file .avi
By aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 14:17 -
Resync Audio in WMVs?
By FuzzyReets in forum AudioReplies: 0Last Post: 19th Nov 2009, 18:33 -
Resync Audio & Video Of A x264 Movie
By IMAN_r in forum EditingReplies: 2Last Post: 10th Dec 2008, 19:06 -
Audio Damaged After Video Conversion. How to Fix?
By Fluoresce in forum AudioReplies: 1Last Post: 5th Aug 2008, 04:01 -
Playing/Fixing a Damaged AVI Video?
By Gildor57 in forum Software PlayingReplies: 5Last Post: 23rd Oct 2007, 21:58
