Is anyone familiar with Ulead Moviefactory 6?? I just made a slideshow for my class and when I burned a trial copy discovered that there are no transitions between the slideshows. I have about 30 chapters(slideshows) in the DVD. There are transitions within each chapter but none between chapters. I hope this makes sense. I need to know if it is possible to have transitions between each chapter and the how to find them. Right now it goes to a black screen and trasitions abruptly.
Thanks![]()
I don't have it but some here in VH use it.
If you don't get an answer soon, try Corel's forums below
http://phpbb.ulead.com.tw/EN/viewforum.php?f=2 -
1. Click on the "Edit" room option, then "Effects". Click on the "Storyboard/Timeline" button to toggle the menu to "Storyboard" view.
2. Select a transition under the "Effects" tab. Drag the transition between two of your video clips at the bottom.
3. Toggle the "Storyboard/Timeline" button to "Timeline" view. Click on a video clip in the video timeline at the bottom of the program. Click on the "Fade In" and "Fade Out" buttons above the timeline window.
4. Click "Next" to design a DVD menu for your project.
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 01:59 -
Ulead MovieFactory old/new version template compatibility?
By GSP_87 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2009, 01:12 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
