Results 1 to 10 of 10
    Jun 2010
    U.S.A.
    I am trying to use AVI Demux & Virtual Dub to remove the first 18 seconds of a video exactly the way I want said thing to be removed & the video output is not starting the way it should. Why is this ? Why am I having so much trouble with something that should be so simple for these programs but they are giving me a hard time & I am not looking to re encode or re convert just to remove these seconds
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If your 18 second mark is not on a key frame then it is not simple for most programs without re-encoding.
    Jun 2010
    U.S.A.
    Is there any way to force it to be on one ?
    Dec 2005
    Canada
    In VirtualDub delete the selected part, then:
    Video > Smart rendering > Compression and select the same codec as the source (XviD?) then save.
    Jun 2010
    U.S.A.
    Am I deleting the section I don't want ? How do I "delete" it ? Also if I select Smart Rendering & then save a new file it does work. But in VLC the video resolution changes / gets a little bigger 10 seconds or so into it ? That is weird
    Dec 2005
    Canada
    Click Go > Go To Frame.. and insert the frame time, then click the little flag thingy under the slider.
    Edit > Delete.
    [Attachment 7349 - Click to enlarge]
    Jun 2010
    U.S.A.
    That does not seem to work. The new file still starts no where near I am telling it to. Smart Render works but in VLC the new video file resolution changes / gets a little bigger 10 seconds or so into it ? That is weird
  8. Member olyteddy's Avatar
    Dec 2005
    Go back up to post #4 and check that all parameters are the same (frame size, bitrate, etc.) and try again?
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Without knowing what type of video we are dealing with....this thread going nowhere.
    Jun 2010
    U.S.A.
    It is a 800mb AVI / XVID with one frame size & one video & one audio codec, birate etc. Everything is the same. It is only VLC that does that weird resize thing
