Hi. A month ago I downloaded mkvtoolnix 4.7.0 and it worked a treat. Until today. I noticed a new version, 4.8.0, so tried that but the problem is identical. It's the same with both the installed and portable version.
First, I get this message:
“Incompatible mkvmerge version.
The GUI is configured to use the mkvmerge executable from a different version () than the GUI itself (mkvmerge GUI v4.8.0 built on May 24 2011). This is not supported but will not be prevented either. You should change the mkv executable in the preferences dialogue.”
The '… not be prevented' comment sounding promising but no. Trying to load a file generates a “File identification failed” message.
Back to the initial message where it says 'You should change the mkv executable in the preferences dialogue'. I can't see a 'preferences' button anywhere so that's a dead end.
Does anyone know what the problem could be here and the cure for it?
The only A/V related thing I've done since mkv last worked is install a codec qmpeg.acm. Wasn't of use to me so I deleted every reference to qmpeg in C drive and registry.
Many thanks for any suggestions.
	Try download the portable version, https://www.videohelp.com/download/mkvtoolnix-unicode-4.8.0.7z , extract it to a folder and run mmg from it.
 edit: missed that you already tested.
 What's your os? I'm running it in win7 64bit without any problems.
 And you find the preference under File->Options and under mkvmerge.
	Hi Baldrick. Same as you - W764. As regards preference, what does one do there? It's just a drop down box for files within your own PC...
	You select the mkvmerge.exe from the mkvtoolnix folder.
	Aye, that's what I thought. It was already there.
 Seems I'm stuck with an inexplicable failure...
	But you can select it again and it will add the full path.
	You, Sir, are a genius. Seriously, this is not the first time you've solved a problem for me and I'm sure you've been a great help to others also. Long may you prosper. Thank you!
  MKVtoolnixBy jjis in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 13:41
  Virtual Clonedrive no longer workingBy Silver Fox in forum Software PlayingReplies: 0Last Post: 23rd Mar 2010, 12:26
  iDVD / Toast Compression No Longer Working?By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 12:57
  MkvToolNix Help....By theninger in forum Video ConversionReplies: 9Last Post: 25th Aug 2008, 09:47
  ac3filter - back speakers no longer working for Prologic outputBy pglenn in forum AudioReplies: 0Last Post: 7th Nov 2007, 00:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
