Hi,
Let me start off by saying, I'm new to this. I downloaded the Philips toolkit 2.0 to create my vcd. I was able to load my photos but it won't accpet my mpeg video. An Error comes up saying it is not a valid video,audio or mpeg file.
The video was taken with my digital camera. I tried using Tmpge but it only converts my mpeg into an mpeg, and still comes up with same error.
Is it something I'm not doing correctly, or should I use a different program other than Philips toolkit...(I need a program that will let me do video and stills)
Any help would be great....
Thanks,
Peter
For a vcd compliant mpeg, you use tmpgenc to encode it again, you must use the right template for your mpeg though or it will not turn out right. I believe if you are capturing this video, you can change the settings so that the mpeg file will be comliant already. Not sure there though as I don't capture.
One of same codecs not accepted by TV.
By sensini in forum Video ConversionReplies: 20Last Post: 27th May 2011, 15:58 -
MKVMerge files not accepted by my Seagate player
By cal_tony in forum Video ConversionReplies: 2Last Post: 9th May 2010, 13:57 -
Help wanted: Video file not accepted by YouTube ($100 reward)
By daveklee in forum Video ConversionReplies: 13Last Post: 5th Mar 2009, 04:06 -
By daveklee in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 03:18 -
By daveklee in forum Video ConversionReplies: 3Last Post: 11th Feb 2009, 19:37
