Hi guys
First want to say Hello to everyone and best wishes to you all
I got a big mission here, have to got the TS file with these requirements:
Output format: MPEG-2 TS files
PSI Period <=100ms
TS output index: The ETR290 standard is met
TS Output bitrate: 8Mbit/s
Bit rate control: Constant bit rate(CBR)
Encoding format: H.264(MPEG-4 AVC)
Profile and level: High Profile and level 4.0 or 4.1
Encoding complexity: Medium or higher encoding complexity is recommend
Video bit rate: 8Mbit/s
Encoding resolution: 1920x1080
Frame rate: 25 frames/second
Group of pictures(GOP) length:36
GOP Structure: Open GOP
This one will maybe used for the HD VOD. I have try to use tsMuxeR GUI but subtitle not automatically shown, even with movie with hard-subbed
Please give me a hand.Thanks
conversion blu-ray to dvd that select audio/subtitle tracks as requirement
By wisitch in forum Video ConversionReplies: 1Last Post: 5th Dec 2011, 05:13 -
By wisitch in forum Video ConversionReplies: 4Last Post: 25th Nov 2011, 07:04 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
How to convert MKV to VOB but without subtitle loss?
By c1steady in forum Authoring (DVD)Replies: 13Last Post: 14th Sep 2009, 07:31 -
How convert MKV to VOB but without subtitle loss?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 03:55
