Is there anyway to take the subtitles from a SD-DVD and add them to a BlueRay file or disk which does not have any subtitles?
Yes. But you will lose the blu-ray menus. Extract the subs from the dvd with vsrip. Convert to srt. Reauthor the blu-ray with multiavchd and the new subs.
Just to be clear you understand, there is no program equivalent to VOBBlanker for BluRay discs and thus no way to simply add a new audio or subtitle track to a BluRay rip and keep the menus like you can with DVD. If you want to add anything at all to a BluRay rip, you have to author a new BluRay disc, which means whatever menus you have will be limited to whatever you can create with a tool like multiavchd.
You could convert the ripped movie to MKV file easily enough without converting or re-encoding anything and just add the subtitles to the MKV file. I don't do that so I'm not sure that you need, but I think that a program called MakeMKV can convert rips to MKV.
How to add SRT subtitles to a DVD?
By sldvd in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2011, 13:39 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
How to backup and add new subtitles to a DVD
By Paddington in forum User guidesReplies: 73Last Post: 6th Oct 2008, 22:19 -
How can add subtitles to dvd with 2 angles
By siopilos in forum SubtitleReplies: 0Last Post: 21st Jul 2008, 16:17 -
How to add TWO subtitles .srt on the same DVD?
By DaPuertorican in forum ffmpegX general discussionReplies: 1Last Post: 5th Jan 2008, 13:54
