For example, I have project A and project B, they represent two videos. I want to combine the two projects and export into one video. Anyone knows how to do this? Many thanks.
I have tried exporting two videos from the two projects independently, and import the two videos into a new blank project and export again, but the quality is not very good.
both projects must have identical settings to import one to the other
otherwise, render one video to the other projects settings and place it on the timeline
Corel VS X2 also has their own forums for future reference
http://phpbb.ulead.com.tw/EN/viewforum.php?f=1Last edited by zoobie; 12th Jun 2011 at 16:28.
You can try exporting the videos from the two projects independently, and import them into a new blank project, then export again. The quality may decrease.
Also, open project A, and use the "insert video command" to insert project B into the timeline. hope that helps!
Need help on using Corel VideoStudio X2
By natural4862 in forum Video ConversionReplies: 8Last Post: 12th Jun 2011, 06:13 -
Help Needed Regarding 'Corel VideoStudio X2'
By oedipust in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 06:49 -
Corel VideoStudio X3- Snapping
By Meroko in forum EditingReplies: 5Last Post: 24th Jun 2010, 19:21 -
templates for Corel VideoStudio X3?
By wingfan in forum EditingReplies: 2Last Post: 25th Feb 2010, 15:10 -
Corel VideoStudio 12
By netmask56 in forum EditingReplies: 4Last Post: 20th Nov 2009, 01:25
