Is there a karaoke/subtitle-timing program that is simple to the point of pressing a hotkey to set the lines to the current frame of a video? I've yet to come to any real understanding about the advanced workings of Aegisub (to be honest, I still haven't even figured out how to manually set the timing in it - it never seems to work right), and I honestly just want a simple timesetting program with no frills or effects, that can export to .ass (or any Aegisub-compatible format).
Basically what I'm looking for is the ability to paste raw text (or import Aegisub-generated "blank" (untimed) lines) and simply allow me to set the timing against a video file by playing the video and pressing hotkeys to set the start/end times of the each line and preferrably auto-commit and go to the next line automatically so I can simply play the file once through and have rough timings throughout the entire subtitle set. I've heard this method being called "punch-in" subtitling, but I can't find any applications that will let me DO it. In addition, and this is my main goal, something that can do the same thing with karaoke timing (in \kn tag format). Once these "rough" timings are done, I want to import them back into Aegisub to manually perfect the timings and apply styles to them.
Surely a program capable of this must exist - surely someone else must have had this same problem - I've just yet to find the right software for it. If Aegisub itself is capable of this, I've yet to figure out any method of activating it or even anything suggesting that it's possible.
Results 1 to 1 of 1
Fastest Method to "Downcoding" a Video to 480p?
By Phantoms Cry in forum Video ConversionReplies: 2Last Post: 2nd Dec 2011, 17:40 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
MPEG-2 HDTV to SD-DVD - "best" method
By Killer3737 in forum Video ConversionReplies: 13Last Post: 19th Feb 2010, 10:23 -
Enable editing of "Hide" timing of subtitles in Subtitle Workshop
By ecc in forum SubtitleReplies: 2Last Post: 31st Jan 2008, 07:35
