Hi,
I have some software setup files saved in my external HD. Whenever I do double click to open them a popup message comes up and shows "parameter is incorrect". I have also tried opening through right click and choosing "run as administrator" but same popup message comes. But, they open correctly when I run the same from my laptop HD!!!
Can anybody help me on this issue??![]()
Could be the software simply doesn't want (ie: support), having those files on a different drive, or on an external drive. Check with the software manufacturer.
Google is your Friend -
Hi Krispy,
I'll do that, but why it is with .exe files only. All other extension files that I have in my external HD are running smoothly. Then what is the parameter problem with .exe files ??
Thanks,
VOB2MPG - How to use /DVDInfo parameter
By mmoore99 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 2nd Mar 2012, 01:05 -
FFMPEG -mbd parameter
By Klagar in forum Video ConversionReplies: 2Last Post: 30th Sep 2010, 14:24 -
Highlight parameter breaks redirect
By thecoalman in forum FeedbackReplies: 0Last Post: 21st Jun 2010, 12:18 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
converting avi to wmv in wme9...incorrect parameter?
By sixinsouth in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2007, 12:45
