Hi guys, just need a little help as i am stuck trying to playback a video file.
Currently have a .mkv and .dts file. I was able to get the mkv to play and audio is heard, however, it is in russian. I can hear english in the background but mostly what i hear is russian. According to VLC media info, it indicates the following:
Stream 0 shows to be the video and indicate a language of english
Stream 1 shows to be audio type russian is the language
Now the dts file when played is the english sountrack only, however, i can get it to play with the video file itself!
I wonder if there is a way to either a) remove the russian from the mkv file or b) play the mkv file using the dts file
Im a little bit confused as to how this works, any help is appreciated!
Thanks!
Yeah it is a separate file completely that only has audio on it when opened. When i play the mkv file, there is only russia language available to choose from.
You should be able to mux in the english audio track into the MKV with MKVtoolnix
If you don't want the russian audio demux everything you want from the MKV with MKVcleaver, subs, video, etc. then remux them into a new MKV.
Wonderful fiasco that is the mks file...
By cprebble in forum SubtitleReplies: 2Last Post: 16th Apr 2012, 22:50 -
synchronizing video and audio in a remuxed MKS
By wsw70 in forum Video ConversionReplies: 0Last Post: 18th Jul 2011, 06:37 -
HD .M2TS with .DTS audio playback
By rajsharma714 in forum Blu-ray RippingReplies: 2Last Post: 8th Oct 2010, 12:00 -
MKV/DTS video playback out of sync
By johnc10 in forum Software PlayingReplies: 1Last Post: 16th Oct 2009, 15:31 -
DTS playback supported on Mac?
By dmahh in forum MacReplies: 1Last Post: 2nd Aug 2007, 19:14
