Normally I follow following diagram:
1) Using any commercial BDDecrypter like AnyDVDHD, rip the BD contents to HDD.
(Keep in mind this step requires almost 50GB space on HDD.)
2) Demux BD-Video.m2ts to raw video.264 or video.h264, audio.dts and audio.ac3.
3) Down convert BD-Video.m2ts video bit-rate to desired video bitrate by using XMedia Recode or HandBrake.
(Normally Video Bitrate => 5000+ kbps would be enough, but its your choice.)
Copy audio.ac3 (or audio.dts) "AS-IS" pass-thru' will maintain professional (hardware-mixture) quality.
GUIDE 1 : Ripping Blu-Ray with HandBrake (wiill pass-thru' DTS n AC-3)
GUIDE 2 : Blu-Ray to MKV / MP4 using XMedia Recode *
* NOT SURE ABOUT DTS n AC-3 PASS-THROUGH,
But you can only encode raw video stream without audio in XMedia Recode.
GUIDE 3 : How to Convert Blu-ray to MP4 HD or MKV HD (using RiPBot Guide by Baldrick)
RiPBot has a feature for Audio Stream Copy -> DTS n AC-3 PASS-THROUGH, i guess.
4) Re-MUX video.h264 and audio.ac3 either to output.mkv or output.mp4.
in case of HandBeake n RiPBot, DTS n AC-3 pass-through, step 4 can be avoided.
Any better suggestions are most welcomed! Plz.
Results 1 to 9 of 9
True. But I often encode a couple of BD>MKVs overnight, so I like to batch them together in Ripbot from AnyDVD HD rips. I've also ran into a few, mostly non-US BDs that I need to run through tsMuxeR to get the correct audio stream and it seems easier with the ripped BD. But Ripbot is a great program. (Donations are accepted at: http://forum.doom9.org/showthread.php?t=127611
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Simple MKV to MP4 Conversion Guide (Xbox360)
By Cloud101 in forum User guidesReplies: 35Last Post: 8th Nov 2011, 16:41 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
bluray rip mkv to mp4 for the xbox
By t-mac in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Jun 2009, 21:58
