hey whats up?
Currently i am using spruceup to author my dvd disc and then nero to burn it (following the how to on this site). I have to use nero as spruce up sees my burner (pioneerdvr-104) but will not burn anything on it at all.
At anyrate i have made dvds with menus that play fine on my pioneer homedecks as well as the older apex ad600a.
The other day i tried them out on a friend's machine that was a magnavox. It refused to read the disc (metnioned to put in a playable dvd). I then tried a dvd-r that was made with another program and it played fine.
my question is have any of you/do any of you use the nero method to burn and if so could you please tell me what machine(s) it was tested on? Im curious as to how compatible it really is. yes im using the current version of nero. thanks again.
PS i would/could use sonic dvdit, but the le and PE both seem not to like video bit rates higher then 8, some of mine jump as high as 10 so sonic is out of the question (it will not author the final disc or dvd folder)
Results 1 to 1 of 1
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 19:29 -
Compatibility issue between Cameo Grabster 200 and Vista
By nawp in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 09:12 -
Help! My DVP5960 has compatibility issue with Seagate FreeAgent 500GB drive
By agidol in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Dec 2007, 08:50 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:20 -
PAL + NTSC Compatibility Issue !?
By ells6363 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2007, 12:37
