Hey guys,
Say I have 3 camcorders shooting an event, Cam-1, Cam-2 and Cam-3. These are all consumer grade camcorders such as the Panasonic HS900.
Cam-1 is set stationary on a tripod and shoots the entire set continuously, say from 1pm-3pm.
Cam-2 and Cam-3 are handheld and shoot intermittently between the same 1pm-3pm period.
So the resulting files would be a 2 hour long video from Cam-1, and multiple shorter videos from Cam-2 and Cam-3.
My question is, if possible, how can I get the footage from all 3 camcorders to align in the timeline in an NLE without having to manually arrange them?
If the manual method is the only possible way, is there any preferred method which can be recommended.
Thanks in advance!
One way is to shoot all three cams continuously - even when you don't want to (i.e. just shoot with them pointing at the floor!).
Cheers,
David. -
Uhuh I was thinking that too, however only the static cam will be tethered to a mains power supply while the other two will be running on batts. Prolly alright for short events though.
Plural eyes seems pretty good, wonder how it manages to sync the clips so intelligently. Does it synch by matching audio? Guess not since the audio from the diff cams would be diff anyway... or is it reading timesamps metadata on the files themselves? If so then I suppose all the cams have to be set at the absolute same date. Curious on how it works so well.
Syncing DV footage with external audio recording - different speeds?
By mjl5007 in forum EditingReplies: 5Last Post: 20th Oct 2011, 06:19 -
Vegas 8.0 splits footage into multiple files!
By PapaDmitry in forum EditingReplies: 2Last Post: 4th Oct 2010, 18:33 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24 -
Trouble syncing Camera footage with additional audio source
By Apollonas in forum AudioReplies: 2Last Post: 8th Apr 2010, 08:45 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 05:54
