  1. what os would give be the best hd playback, vista x86 or x64?
    thanks.
    Oct 2005
    666th portal
    makes no difference at all.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I know for over 3 (or so) gigs of ram to be recognized you need a 64bit OS, so by having say, 4 or 8 gigs of ram as opposed to 2 or 3 gigs of ram, would that make a difference for HD playback ?
    I'm talking mobo memory not video card memory.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Probably only if you are using onboard graphics and not a dedicated video card that supports hd and h264 specifically. But if you get a sub 100.00 card that does support hd and h264 than system ram should be less vital since the graphics card will take more of the burden of decoding away from the cpu and system in general.
