Results 1 to 12 of 12
    Jul 2004
    Italy
    Hi All,
    when I had a windows, I used ImgBurn ( wonderful tool)
    now I have an Imac and quite frankly I don't think that it can be used
    any valid alternative?
    thanks a lot/Fabio
    canada
    Thread moved to the mac forum where you can get more help.
  3. sounds like you need Toast
  4. for burning purpose I use LiquidCD (donationware)
    For DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
    Jul 2004
    Italy
    thanks but I'd need something for DVD
    Liquid seems only for CD, correct?
    Jul 2004
    Italy
    ok sorry it is also for dvd
  7. Banned
    Freedonia
    There's nothing really as good as ImgBurn for Macs, but I use Burn (freeware) and it's OK. It doesn't have a lot of options but if you just need to burn something it's OK.
    Many people who have Macs will run a virtual machine on the Mac with Windows. If you do that you can run ImgBurn inside a Windows VM.
    Jul 2004
    Italy
    any other option available ( if possible free)?
    thanks
    Jul 2004
    Italy
    I have an .iso file ( 4 GB) and burn doesn't recognize it
    with liquid cd there are some errors in the writing process
    any other software?
    thanks
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Toast is it (3rd $party).
    Jobs is anti-optical anything. You bought into his plan when you purchased that iMac.
    With Mac you can run Linux alts. Best to keep a running Windows machine.
    http://www.kiva.org/about
    Jan 2006
    Disk Utility will burn DVDs and it's free and already on your Mac.
