I was having trouble with a video editor recently and read that a certain codec would probably help. I found the codec (qmpeg.inf), did 'right click/instal' but my problem wasn't fixed. So I thought I'd uninstall the new codec but I'll be damned if I can find it. I've scoured the list obtained via Gspot but can't see it (although there's that many I may have missed it).
The qmpeg codec isn't bothering me, it's just curiosity – where are codecs found in Windows 7 and how does one go about uninstalling?
Many thanks.
In Win7, if it's a 32 bit codec it will be in C:\Windows\SysWoW64. If a 64 bit codec it will be in C:\Windows\System32. The INF file isn't the codec, just a small text file that describes how to install the codec. The real codec file is probably a DLL, ACM, or AX file.
Hello (again) jagabo and thank you for that. I found qmpeg.acm where you said – it's 'creation date' was the day I installed it* so I just deleted it. I had a poke around in the registry and there's a tree as follows: HKEY_CLASSES_ROOT/SOFTWARE/Microsoft/Multimedia/Components/installed/codec_qmpeg.
From that, there's a reference to C:\Windows\INF\qmpeg.inf. So I went there and found the file qmpeg.inf. D'you reckon I can safely delete it too? And the registry file?
The reason I want rid is that I've just found a number of references to qmpeg.acm being problematic. For example:
http://www.superantispyware.com/malwarefiles/QMPEG.ACM.html
*Thanks for telling me that qmpeg.inf was just a text file. That explains why the folder I downloaded contained qmpeg.inf and qmpeg.acm. But I didn't touch the latter. I right-clicked the inf file and there was an option to instal which I clicked. Something flashed on the screen too fast for me to see and that was that.
Many thanks
Location Videohelp.com
By anon_private in forum Off topicReplies: 3Last Post: 24th Oct 2010, 21:59 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
SRT display location
By ckamc in forum SubtitleReplies: 2Last Post: 23rd Apr 2008, 22:00 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52 -
Invalid Location
By Justgrant2009 in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2007, 18:48
