Thanks to budwzr (on another thread) I've now discovered Sony Vegas Movie Studio HD Platinum 10. The purpose is to make a single video out of a number of clips (different formats, different sizes). I tested the Vegas with 9 files - 4xwmv, 4xavi and an mpg. The result was good bar the fact that audio dropped out in the middle. I checked the timeline and there it was - videos 5, 6 and 7 showed no audio.
Videos 5 -7 were all avi so I thought that was the problem until I realised the 4th avi clip rendered fine. I experimented and found that I could load the 3 rogue videos into Vegas perfectly well as long as I did them on their own. That defeats the purpose, of course. Try as I might, I can't get these 3 clips to load their audio into a timeline which already contains clips.
Very odd and annoying. Can anyone suggest a reason/cure?
My thanks for any replies.
what kind of avi files, what kind of audio , what kind of video ?
use mediainfo (view=>text) copy & paste the info back here
You could convert the audio to pcm wav (uncompressed audio). You might use vdub for this (video=>direct stream copy, audio=> full processing mode, audio=> compression, no compression ; file=> save as avi ) then import into vegas -
Hello poisondeathray. I've used mediainfo and made two caps - the audio info of the 4 avi files used in my 'vegas test' and the corresponding video info. A lot of text hence the caps rather than posting direct.
To recap, the 4th avi file is fine in vegas. The first three load fine ON THEIR OWN but, when added to an existing timeline, I don't get audio.
If they will load singly, then right click the audio and "open in audio editor", then save as PCM. To specify the audio editor look in "preferences. Use Audacity if you don't have anything.
If that doesn't work, install K-Lite. Then everything will be hunky-dorry.
Many thanks to you both for taking the time to look at this. I've succeeded in making my video by using virtualdub to give a PCM audio track. This was doubly handy as a couple of the clips I was joining needed their volume reduced.
I was thinking of installing K-Lite as suggested by budwzr as I wouldn't mind being able to use vegas on its own without having to re-edit the odd clip. But I already have Shark007's codecs and, as I understand it, it's supposed to be the most comprehensive codec pack available. Would either of you suggest otherwise?
It's interesting how changing the audio to PCM doubled the size of the clips but at least it works. The size of my newly created video was a surprise too but then I noticed it was avi which always takes a lot of space. So I tried it as mpeg2 and the quality was fine. Even mpeg1 (half the size of mpeg2) was fine.
Thanks again lads.
Sony Vegas - Scripting - Adding track motion preset
By samsam in forum EditingReplies: 1Last Post: 7th Oct 2020, 01:52 -
Sony Vegas 7: Where's the video on the track?
By cstar7777 in forum EditingReplies: 3Last Post: 24th Mar 2011, 19:29 -
No audio track when importing mpeg2 into sony vegas? How do I fix this?
By bojadada in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2009, 11:53 -
ifoedit/sony vegas-->sound problems
By carock in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2008, 11:28 -
Sony Vegas 8 - Track Motion Preset saving???
By sdsumike619 in forum EditingReplies: 2Last Post: 4th May 2008, 01:47
