Hi.
I use to work with textsub.vdf filter to add subtitles to videos on my old PC which ran on Win Xp SP2.
I haven't used Virtual Dub in some time. I just downloaded it for my new PC, which is 64-bit and runs on WIN 7.
But the TEXTSUB.VDF filter won't work here.
It says
CANNOT LOAD PLUGIN MODULE " location of the file " THE SPECIFIED MODULE COULD NOT BE FOUND.
Is there anyone that can help me with this, I really need to get this to work.
Are you using vitualdub 64bit version? If so try virtualdub 32bit. It work just as fine.
Hello, everyone! (^_^)
Please have a look at my suggestion on this topic. I've just tested it with both versions of VirtualDub 1.9.11 (x32 and x64), and the filter doesn't show on the list with VDub x64, but it does show in VDub x32.
Bye!
TextSub filter: how to set a new style?
By Instant Martian in forum SubtitleReplies: 3Last Post: 5th Aug 2011, 13:26 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47 -
problem with accented letters using textsub in Virtual dub Mod
By Deathknight in forum SubtitleReplies: 2Last Post: 29th Apr 2008, 22:47 -
Is there any filter (plugin) for Virtual Dub that will simulte DirectShow ?
By donthenet in forum Newbie / General discussionsReplies: 8Last Post: 14th Dec 2007, 08:44 -
How to create my own default Textsub filter settings?
By GoldNiv in forum SubtitleReplies: 3Last Post: 2nd Nov 2007, 11:44
