I can't figure this one out. I've got 2 videos that I've encoded with Handbrake. Now Handbrake seems to be pretty insistent on encoding as VFR, but I think I've finally found all the right settings and have it spitting out CFR video again. So I've encoded 2 videos that are CFR, and when I join them with MyMP4Box GUI, they come out as VFR.
How do I fix this?
Original Video 1
Original Video 2HTML Code:General Complete name : C:\WP\Vids\2MOV002-3.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 171 MiB Duration : 13mn 18s Overall bit rate : 1 798 Kbps Encoded date : UTC 2011-06-08 15:12:17 Tagged date : UTC 2011-06-08 15:36:00 Writing application : HandBrake 0.9.5 2011010300 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 13mn 18s Bit rate mode : Variable Bit rate : 1 601 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.155 Stream size : 152 MiB (89%) Writing library : x264 core 112 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2011-06-08 15:12:17 Tagged date : UTC 2011-06-08 15:36:00 Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 13mn 18s Bit rate mode : Variable Bit rate : 192 Kbps Maximum bit rate : 233 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 18.3 MiB (11%) Encoded date : UTC 2011-06-08 15:12:17 Tagged date : UTC 2011-06-08 15:36:00
Joined VideoHTML Code:General Complete name : C:\WP\Vids\2MOV001-1.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 9.75 MiB Duration : 35s 29ms Overall bit rate : 2 336 Kbps Encoded date : UTC 2011-06-08 15:10:53 Tagged date : UTC 2011-06-08 15:12:06 Writing application : HandBrake 0.9.5 2011010300 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 34s 935ms Bit rate mode : Variable Bit rate : 2 144 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.207 Stream size : 8.93 MiB (92%) Writing library : x264 core 112 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2011-06-08 15:10:53 Tagged date : UTC 2011-06-08 15:12:06 Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 35s 29ms Bit rate mode : Variable Bit rate : 192 Kbps Maximum bit rate : 219 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 821 KiB (8%) Encoded date : UTC 2011-06-08 15:10:53 Tagged date : UTC 2011-06-08 15:12:06
HTML Code:General Complete name : C:\WP\Vids\Joined.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 181 MiB Duration : 13mn 53s Overall bit rate : 1 821 Kbps Encoded date : UTC 2011-06-07 16:38:04 Tagged date : UTC 2011-06-07 16:38:04 Writing application : My [url=https://www.videohelp.com/tools/MP4Box]MP4Box[/url] GUI 0.5.5.4 <http://my-mp4box-gui.zymichost.com> Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 13mn 53s Bit rate mode : Variable Bit rate : 1 624 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 29.970 fps Minimum frame rate : 29.920 fps Maximum frame rate : 30.040 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.157 Stream size : 161 MiB (89%) Writing library : x264 core 112 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2011-06-08 15:10:53 Tagged date : UTC 2011-06-07 16:38:16 Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 13mn 53s Bit rate mode : Variable Bit rate : 192 Kbps Maximum bit rate : 219 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 19.1 MiB (11%) Encoded date : UTC 2011-06-08 15:10:53 Tagged date : UTC 2011-06-07 16:38:16
Results 1 to 1 of 1
linking mp4s together(program)
By Dr.Gee in forum Newbie / General discussionsReplies: 4Last Post: 3rd Sep 2010, 05:14 -
MP4s - how to correct them, then join them together?
By extent in forum Video ConversionReplies: 2Last Post: 15th Aug 2010, 16:06 -
Selective subtitles on MP4s
By phunkidude in forum MacReplies: 6Last Post: 8th Feb 2010, 14:44 -
VFR
By Baldrick in forum GlossaryReplies: 0Last Post: 6th May 2008, 03:39 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 10:30
