fft3dfilter(sigma=9.0,sigma2=5.0,sigma3=8.5,sigma4 =4.0, bt=4, bw=8, bh=8, ow=4, oh=4,plane=3, sharpen=0.0,interlaced=false,dehalo=0.0) #
fft3dgpu(bt=4,sigma=9.0,sigma2=5.0,sigma3=8.5,sigm a4=4.0,bw=8,bh=8,ow=4,oh=4,sharpen=0,plane=0,mode= 1,precision=2,interlaced=false,oldfft=false)
fft3dfilter(sigma=9.0,sigma2=5.0,sigma3=6.5,sigma4 =6.0, bt=4, bw=8, bh=8, ow=4, oh=4,plane=3, sharpen=0.0,interlaced=false,dehalo=0.0) #
fft3dgpu(bt=4,sigma=3.0,sigma2=2.0,sigma3=5.5,sigm a4=6.0,bw=16,bh=16,ow=8,oh=8,sharpen=0,plane=0,mod e=1,precision=2,interlaced=false,oldfft=false)
That's what i used basically
Results 61 to 90 of 108
I'd like to try with neat + fft3d problem is i can't find a good frame (flat, featureless area in your video). If you can provide a sample with such frames that'd help
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I think there are different several removedirt and removegrain versions (and several versions of those versions! - it's very confusing, trust me). Try using the one that is not labelled sse2 or sse3. In the QTGMC at doom9 thread, there are links to several removedirt versions in a zip file
e.g
removedirt.dll
removedirtSSE2.dll
removedirtSSE3.dll
You should only have 1 version of a particular in the plugins directory (otherwise conficts occur). I'm using the SSE2 version, but I think the removedirt.dll version should work . I read somewhere that the SSE3 version is unstable (I can't recall if that was for removedirt or removegrain)
Jagabo said adding chubbyrain2 to the original script you used worked in clearing up those moving lines, so you can try that too.Last edited by poisondeathray; 18th Jun 2011 at 13:07.
and what about the removedirtMC that is in the previous script ?
i may drop some fonctions for it to work , thanks a lotLast edited by smartel; 18th Jun 2011 at 15:03.
RemoveDirtMC isn't a .dll , it's a modified function based on RemoveDirt. It's MC (= motion compensated) , so tends to be more selective accurate (less blurry) than the original RemoveDirt function .
I'm sure I posted it on VH before .If you can't find it I'll dig it up
EDIT: just copy these to the bottom of your script. There are seveal versions of this floating around too. This one has been modified to work with mvtools 2.x
Code:function RemoveDirt(clip input, int limit, bool _grey) { clensed=input.Clense(grey=_grey, cache=4) alt=input.RemoveGrain(2) return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=6,cthreshold=8, gmthreshold=40,dist=3, dmode=2,debug=false,noise=limit,noisy=4, grey=_grey) } function RemoveDirtMC(clip,int limit, bool "_grey") { _grey=default(_grey, false) limit = default(limit,6) i=MSuper(clip,pel=2) bvec = MAnalyse(i,isb=false, blksize=8, delta=1, truemotion=true) fvec = MAnalyse(i,isb=true, blksize=8, delta=1, truemotion=true) backw = MFlow(clip,i,bvec) forw = MFlow(clip,i,fvec) clp=interleave(backw,clip,forw) clp=clp.RemoveDirt(limit,_grey) clp=clp.SelectEvery(3,1) return clp } -
fft3d + neat: http://www.sendspace.com/file/fpt5st
how long did it take to process that ??
have you kept the settings ?
can avisynth import neatvideo and it's setting ?
anyway i got lots of help from you guys but .... nothing seams to really work always get an error
i got avisynth installed (2.5) and i'm mostly importing the plugins from the avisynth version inside megui
i must have something not setup right or conflicts grrrrrrrr duh !Last edited by smartel; 18th Jun 2011 at 20:37.
well took me some time i got a Pentium 4 (before dual cores era....) you can use it avisynth but i think you need the pro version, but you can try, i know on mine i got a warning first but it's processing the video anyway (home version)
You would write it like this:
noise profile: http://www.sendspace.com/file/27ixvyAvisource("C:\Source2..avi", fourCC="HFYU", pixel_type="YUY2")
Assumetff()
separatefields()
weave()
ConverttoRGB32(matrix="rec601",interlaced=true)
LoadVirtualDubPlugin("C:\Program Files\VirtualDub-1.9.8\plugins\NeatVideo.vdf", "NeatVideo", 1)
NeatVideo("C:\Program Files\Neat Video for VirtualDub\PROFILES\blablabla.dnp", "C:\Program Files\Neat Video for VirtualDub\PRESETS\blabla.nfp", "1.0", "1", "1", "1")
ConvertToYV12(matrix="rec601",interlaced=true)
filter preset:http://www.sendspace.com/file/o3b5zyLast edited by themaster1; 18th Jun 2011 at 20:49.
isn't neatvideo time limites for unregistred users ? would have to do 30 min chunks i think ?
i'll get back to you later
what plugins to i load for this script to work ?
only FFT3DFilter.dll ?? of maybe something a little bit faster ??Last edited by smartel; 18th Jun 2011 at 21:13.
Perhaps i never tried on such lenghty videos (5 min max), also according to my tests the video is processed but not as good as if you use it directly in vdub , again for home version, probably an intentional bug.
It's probably a good idea to first process it with fft3d filters only, save in avi huff (lossless) and then finish in vudb with neat*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Good i'll make a script and feed it to virtualdub , but that will append only tomorrow night ,
for now i've got to go
thx a lot for your help cheers !
script error line 6 collumn 53 ?? expected a,or)
LoadPlugin("C:\Program Files\MeGUI_2008_x86\tools\avisynth_plugin\FFT3DFi lter.dll")
Avisource("F:\100 limites\Nouveau dossier\NATM.1989..avi", fourCC="HFYU", pixel_type="YUY2")
Assumetff()
separatefields()
weave()
i'll look into that more demain , à bientôtLast edited by smartel; 18th Jun 2011 at 21:26.
There's a space between the m and the a in the fourth "sigma" in both fft3dgpu lines.
Yeah there are a few spaces that shouldn't be there:
FFT3DFi lter.dll should be FFT3DFilter.dll
mod e=1 should be mode=1
etc...
It wasn't like that when i pasted the script, strangeLast edited by themaster1; 19th Jun 2011 at 09:25.
error
nly pixel shader 2.0 or higher supported
i have an aiw ve (radeon 7500)
this is for the fft3dgpu fonction -
well if you don't have a good graphic card you can always use fft3dfilter instead of the gpu version the equivalent would be:
for the 1st (gpu version):
fft3dfilter(sigma=9.0,sigma2=5.0,sigma3=8.5,sigma4 =4.0, bt=4, bw=8, bh=8, ow=4, oh=4,plane=0, sharpen=0.0,interlaced=false,dehalo=0.0)
2nd (gpu version):
fft3dfilter(sigma=3.0,sigma2=2.0,sigma3=5.5,sigma4 =6.0, bt=4, bw=16, bh=16, ow=8, oh=8,plane=0, sharpen=0.0,interlaced=false,dehalo=0.0)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
The trial version of NeatVideo does leave their logo on your filtered video. You can try any number of other spatio-temporal denoisers, and many work to varying degrees. I've used it for some very tough problems that gave results I couldn't get any other way. But the product has a learning curve, the full version isn't free; most people set its filters far too high and end up criticizing the product because they haven't learned to use it properly. NeatVideo is used by pros and hobbyists alike, makes versions for Adobe, Vegas, and other bigtime software.
It depends on the problem you're addressing and whether or not you want to put time into something that many users wouldn't want to be without. I bought 3 copies for 3 computers and I'm glad I'm did. As suggested, fft3d also has its points, but it's not a push-button solution either. All of the better denoisers require some learning and fiddling.Last edited by sanlyn; 21st Mar 2014 at 21:41.
The home version works with AviSynth. If you get any errors, their manual and their forum have many tips on using it a number of ways. I used the suggestions in the user guide. Worked for me.
Finally I used your script , managed to make it work
I made one big huffy avi file with virtualdub
a little more than 24h for a 46 min clip
I will convert it to dvd with avstodvd(HCenc) later on
the encoding isn't over yet , i can't wait to see it
i can't see the output filtered with VD while processing ...
Do you think this script would be usefull with most VHS capture ??
or is it just for heavy noise and chroma (rainbow) noise ? -
ok here is my results
i included a sample with lots of whites
looks like it's very close to posterisation (or plastification)
i've included the script i think it's a very good script for 2nd or even 3rd generation VHS
QUESTION
the files looks better on TV with a dvd player ..
what would be a good media player for previewing captured material intended for TV viewing
I once read about mediapleyer classic home cinema and powerdvd being closer (or truer) for TV emulation
are they settings inside MPC-HC or maybe even ffdshow
so they won't change or enhance viewing and stay true to the file ?Last edited by smartel; 24th Jun 2011 at 15:15.
I'm getting errors after trying to save some of these AVI's (VirtualDub says indexing problem). Maybe it's just my system (XP Pro) but I never saw these errors before. Not a major prob, I just go to the next post and follow along.
Source2 above is 712x480 (?)
Never mind. I'll just keep following.Last edited by sanlyn; 21st Mar 2014 at 21:43.
with virtualdub ,doesn't exactly catch the same resolution when asked i don't know why
(set 720X480 or 704X480 for capture i don't remember
with 712 i crop 8 to 704 ( vhs capture sides aren't really well defined, always some kind of garbage)
and my virtualdub saving went fine on my side -
[suggestion] If you're capturing with VirtualDub, aren't you playing this on a VCR? What frame size does your VCR output when playing? If it's 640x480 (4:3 standard definition), capture in VirtualDub to AVI 640x480. Later your encoder should generate the correct DVD frame (for 4:3, I'd use 704x480 for DVD).
True, NV works better that way. But you can also do this (I do it all the time):
- Add ConvertToRGB32 to the end of your avs script
- Open VirtualDub and load NeatVideo with the settings you want.
- Run your AviSYnth Script with NeatVideo still loaded in VirtualDub filters.
I leave VDub's output in RGB for further work, but you can recompress Vdub output to YUV if you want.
I think the problem with running NeatVideo inside AViSYnth is due to color conversion. NeatVideo wants RGB, but internally it uses its own YCbCr colorspace. Maybe it's all that conversion (?). Ya got me. I just never liked running Vdu8b filters in AviSynth.Last edited by sanlyn; 21st Mar 2014 at 21:43.
Video Capture Settings.
By Green_Tape in forum Capturing and VCRReplies: 1Last Post: 4th Oct 2011, 23:37 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 18:45 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 21:05 -
Assistance with Capture settings
By kiwiusa in forum RestorationReplies: 0Last Post: 14th Jan 2008, 19:41
