A friend of mine gave me a DVD with a video in a VED format. I have been searching but unsuccessful in determining how or even IF I can convert this. Any information would be much appreciated!
No, it's definitely marked as VED. I think it was a program she used and it saved it in it's own format (?). Not sure where to go from here.
Explain in more detail how it is "marked" as VED. Is this the three-letter extension of the file? If not, what is the file name? Are there any other files or folders? Any chance you can get the name of the program?
Never heard of this type of file name.
A brief search found a possible candidate - Video Explosion Deluxe, from Nova development, which has a program called Photo explosion deluxe, but no video program listed. My guess would be that this is a project file that will only open with the associated program. If your friend is handing these out they need to learn about supported formats that other people can make use of.
BTW, when I say "a brief search" I mean less than 30 seconds. Where exactly were you looking for additional information? I googled VED video, not all that complex.Last edited by Nelson37; 8th Jun 2011 at 17:08. Reason: More info
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
