I have Adobe Media Encoder : how to convert a .mov file (generated with Alpha Video 3bits) into a .flv with transparency (the original file have a transparent background ?
(The software I have to use first is good but can't generate directly a .flv with a transparent background: I have to use Adobe Media Encoder for this)
Thank you for your help![]()
in AME, using the flv preset, make sure format is set to flv, on2vp6, and checkmark "encode alpha channel" . Adjust the other parameters like bitrate, dimensions as you see fit
convert .mov to flv video - ascpect ratio messed up
By lilly333 in forum MacReplies: 13Last Post: 23rd Jan 2010, 09:30 -
Alpha channel video makes for a larger-than-target bitrate flv
By flvvideo in forum Video ConversionReplies: 1Last Post: 3rd Dec 2009, 12:10 -
convert mov to flv zero bites
By drica in forum ffmpegX general discussionReplies: 46Last Post: 30th Aug 2009, 14:42 -
Can't get sound with mov to flv convert
By TucsonTom in forum ffmpegX general discussionReplies: 1Last Post: 15th Jun 2008, 16:16 -
Problem trying to convert .flv to .mov
By herdofcaribou in forum ffmpegX general discussionReplies: 7Last Post: 10th Feb 2008, 02:16
