Good Afternoon,
After reading through some posts and recommendations, I decided to try RipBot 264 for my mpg to mp4 conversion needs. I downloaded the application from this site and installed it without difficulty.
However, I did have to download ffdshow and Mastroska, which I did and installed without difficulty.
So where is the problem you ask. When I launch RipBot and attempt to open up my mpg file, I get the following:
1. please wait, indexing video stream
2. Can't open /temp/ripbot264temp/job1/getinfo.avs and that is where it ends.
I did check ffdshow to make sure that avisynth was checked and installed. But the error message continues.
A search through the forums using the above subject line, did not offer up any help.
THus, any ideas on where to start ...
Thanks,
Ed
Can you play the mpg without problems in wmp?
Is the getinfo.avs created?
Or use something that does not need any separate software like handbrake, xmedia recode or freemake video converter. -
Baldrick,
Yes, the mpg will play in a number of other players just fine.
No. The avs file was not created or at least the path to that file was not created. In fact, I created that path and retried the process. But alas, no joy in muddville.
Thanks for the other recommendations. I will try those on for size.
Ed.
Ripbot264 1.17
By rapunzel in forum Newbie / General discussionsReplies: 7Last Post: 6th Jan 2012, 17:05 -
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 06:00 -
how does Ripbot264 think ... ?
By zero7404 in forum Blu-ray RippingReplies: 42Last Post: 3rd Oct 2011, 20:23 -
Ripbot264 and DVD's
By leftspeaker2000 in forum DVD RippingReplies: 4Last Post: 10th Mar 2011, 09:41 -
Ripbot264 hanging
By ma2kp in forum Blu-ray RippingReplies: 7Last Post: 13th Nov 2008, 09:59
