Ok, I'm sure I am just missing something but I am in the process of converting 6,000+ slides to DVD.
Scanning did not give me the clarity that I want so I tried to "re-shoot" them using a white board and my Sony Alpha DSLR camera. What I got was stunningly clear copies of my slides when viewed on my PC!
However, after running them through a "slide to DVD" conversion software package the basic slides were "average" in clarity but photo's of text related materials are almost impossible to read!
These completed "slide shows" will be distributed to family members all over the country for viewing on their set-top dvd players and their tv's.
What did I do wrong, or is it just a function of the conversion to NTSC from digital and if so, is there a "work-a-round"?
Regards,
Jay F.
Wisconsin
DVD is only 720x480 resolution. The originals are probably much higher.
You can save the camera files as data to a DVDR for computer viewing, or you can edit the slides for the smaller format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
DVD-video is only 720x480/576 so it's not that simple to make it look nice.
What software did you use? Proshow, MemoriesOnTV and DVDSlideshowgui are my favorites.
Or you can just put the jpg on a CD as most dvd players supports that. But no nice slideshow features. -
No workaround SFAIK other than re-typing all the text. Text just does not downsize very well, and use of the fancier fonts often found in titling makes it much worse.
Transfer 35mm slides to DVD
By btruff in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2017, 19:55 -
DVD SlideshowGUI - Random slides / images missing from the ISO file
By DaveHole in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2010, 06:30 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
Scanning 35mm slides and transferring the pictures to a DVD for viewing
By btruff in forum Newbie / General discussionsReplies: 5Last Post: 25th Jan 2009, 11:45 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38
