Im using virtualdub and delogo to remove some onscreen bits.My question is why is my outfile so massive.The original avi is only 58mb but the output avi is over 4gbs! How do I rectivy this?
Learn how to use VirtualDub and learn the exact meaning of what "AVI" is.
Once you make changes to the video file....you need to add the compression back to the file. -
Yup, just select Video->Compression and select xvid codec.
Pretty much all video filtering involves decompressing the source to uncompressed YUV or RGB before filtering. If you want your video compressed again you have to select a compression codec in VirtualDub.
How do I get the exact file size I want with Virtual Dub ?
By Simmons in forum Video ConversionReplies: 3Last Post: 21st Jul 2011, 01:32 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35 -
how to batch file in virtual dub?
By warlock110 in forum Video ConversionReplies: 2Last Post: 17th May 2007, 00:56 -
Virtual Dubb giving me 4 GB output from 40 meg file
By illpeeonu in forum DVD RippingReplies: 4Last Post: 6th May 2007, 17:23
