  1. Beer-phile
    May 2011
    Great White North
    I'm looking to put banana plugs on my speaker wire for my home theater setup. I have had a few speaker shorts recently that I want to stop (the receiver shuts itself off).
    My question is: What banana plugs are good? I've seen them at $20 for 2, which is clearly outrageous, and as low as $5 for 50. I want good quality without breaking the bank. Is there really any difference between them all? Anything in partular I should look for/watch out for?
    thanks guys
  2. For speaker wire inexpensive plugs are fine. As long as they are decently constructed.
  3. I have these from Monoprice http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=...seq=1&format=2 on speakers for two systems and have never had an issue. Good quality and cheap.
    --dES
    "You can observe a lot by watching." - Yogi Bera
    http://www.areturningadultstudent.com
    Jan 2005
    In addition to Monoprice, there's some at http://www.bluejeanscable.com/store/speaker/index.htm (scroll down a bit) and http://www.radioshack.com/family/index.jsp?categoryId=2032280&allCount=254&fbc=1&f=PAD...23038%3B+jacks, etc...
    I've used the $8 a pair Radio Shack ones (kind of expensive, I'd have tried their $5/pair NXG ones if they had) and Bluejeans cable welded speaker wire with locking bananas. Also have some Bluejeans non-locking ones but haven't used them yet. I would recommend any of them...
    Edit: Those NXG ones look like they're open, still a possibility of a short if strands stick out the holes...
    Put NBC's Ed on Blu-ray!
