Hi everybody
I'm trying to transcode a video PS file to a Transport stream video file with a lower bitrate (9mb/s)
My source video properties are:
Input #0, mpeg, from 'C:/Testing50MbMPEG2.mpg':
Duration: 00:09:35.99, start: 0.943711, bitrate: 53723 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video (4:2:2), yuv422p,
1920x1080 [PAR 1:1 DAR 16:9], 50000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0xa0]: Audio: pcm_dvd, 48000 Hz, 2 channels, s32, 2304 kb/s
I want to get a CBR with Null Packets. but I donīt know how to do it with command line. Audio destination must be in mp2.
Is there any template for TS for using with Avanti?
Thanks for all
Results 1 to 21 of 21
Do you want to keep it HD or downscale to 720x576. For HD, 9mb/s would give very bad results.
There is no template for TS but you could modify e.g. the "MPEG-2 / HQ elementary streams for DVD" template.
1. load above mentioned template
2. set "Container" field to "ts"
3. set "Bitrate", "Min rate" and "Max rate" all to 9000 to force CBR
But this is only useful if you plan to downscale the frame size.
I don't know what Null Packets are. This is what FFmpeg reports with above settings;
mpegts @ 01c2a5e0] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Perhaps someone else can point to more dedicated software for TS encoding?
Thanks for your help
I want to keep the source resolution. I don't know how to insert null packets with ffmpeg.
Another question:
What can i do for keeping the same mapping that i have in the source videofile?
I've got another ts file which has two audio streams with audio descriptors. The stream 0.2 doesnīt appear
Input #0, mpegts, from tests2.ts':
Duration: 00:09:35.92, start: 600.000000, bitrate: 51648 kb/s
Program 1
Stream #0.0[0x1011]: Video: mpeg2video (4:2:2), yuv422p,
Stream #0.1[0x1100](fre): Audio: mp2, 48000 Hz, stereo, s16, 224 kb/s
Stream #0.2[0x1101](eng): Audio: mp2, 48000 Hz, stereo, s16, 224 kb/s
Output #0, mpegts, to 'nul.ts':
Stream #0.0: Video: mpeg2video, yuv422p, 1920x1080 [PAR 1:1 DAR 16:9],
q=2-31, pass 1, 9000 kb/s, 90k tbn, 25 tbc
Stream #0.1(fre): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
http://en.wikipedia.org/wiki/MPEG_transport_stream#Null_packets
It seems that transport streams for ATSC and DVB require strict CBR and to accomplish that the muxer needs to insert dummy null packets. I can't find a option in FFmpeg for that purpose.
It's probably already enough to add > -newaudio at the end of the "User VIDEO options" command line, e.g.;Another question:
-g 12 -bf 2 -dc 10 -flags2 +ivlc -mbd 2 -trellis 1 > -newaudio
At the first pass you won't see the second audio stream but at the second pass it should be there.Last edited by Chris K; 7th Jun 2011 at 08:32. Reason: changed encoder to muxer
not sure, but wouldn't you set the -muxrate in ffmpeg ?don't know how to insert null packets with ffmpeg.
also, don't you need to set the buffer along with bitrate/min rate/max rate ? CBR requires min rate = maxrate and buffer needs to be set
kieranrk is working on open broadcast encoder and x262 (MPEG2), but it's not ready yet
http://code.google.com/p/open-broadcast-encoder/
http://www.ob-encoder.com/ -
Yes true, but if the OP used the suggested template to modify, there is already a VBV buffer size 1835k set.
I tried that this afternoon with a value of 12000 which I found in a example. I then get this...not sure, but wouldn't you set the -muxrate in ffmpeg ?
[mpegts @ 01c67920] muxrate 12000, pcr every 0 pkts, sdt every 3, pat/pmt every 0 pkts
Also looked at the mpegts muxer source code and it's clear it has a function to write null packets. It looks like it does this automatically but indeed I wonder if this requires to use -muxrate. If not used the message shows muxrate VBR...
[mpegts @ 01c50d20] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Was your muxrate 12000 test done at 9000Mb/s video bitrate, and did it alter the filesize compared to using no muxrate ? Wouldn't you expect padded TS to be larger ?
Sorry, I made a few mistakes!
1. muxrate should have been 12000k not 12000.
2. I looked at the video size as reported by FFmpeg.
Should have looked at the muxing overhead (or final file size).
muxing overhead 8.059291% ... muxrate VBR
muxing overhead 33.355141% ... muxrate 12000k
IfoEdit uses 10080k as DVD program muxrate so 12000k looks reasonable.
Get no errors with that. Lower muxrates occasionally give...
[mpegts @ 028805a0] dts < pcr, TS is invalidLast edited by Chris K; 7th Jun 2011 at 15:42.
What do you mean with audio descriptors, this ...
http://en.wikipedia.org/wiki/Audio_description
or simply this ...
-alang code ... set the ISO 639 language code (3 letters) of the current audio stream.
or perhaps still something else? -
I meant to ISO 639. Can you show me an example of command line with 2 audio streams with "fra" and "eng" descriptor?
I've found in Ffmpeg's help an explanation to this case but i don't know how to apply it.
-alang code set the ISO 639 language code (3 letters) of the current aud
io stream
My knowledge of Ffmpeg are very poor.
This is my source video file and i want to get a ts output with two audio streams:
Program 1
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Thanks for your patience -
First a few notes ...
In one of your previous posts you wrote you want 9000 kb/s CBR and keep the 1920x1080 resolution. You can't expect good results when you reduce a 50000 kb/s source to 9000 kb/s and keep the same resolution.
The FFmpeg command line for two audio tracks would look like ...
ffmpeg -i "input.ts" <video options> -alang fre <audio options> -y "output.ts" -alang eng -ab 192k -newaudio
Since your source already has mp2 audio streams, you can also copy them to preserve audio quality ...
ffmpeg -i "input.ts" <video options> -alang fre -acodec copy -y "output.ts" -alang eng -acodec copy -newaudio
The attached zip contains two example templates for Avanti. You need to unpack and copy them to the templates folder and load them at the template USER tab. Please read the comments first after loading. One re-encodes audio, the other copies it. -
I have to get a transport stream with null packets and 2 audio streams. Bitrate must be about 9mb/s and with cbr. Can you show me another idea? I think that the quality is good because source video has a high bitrate (50 mb/s)
Sorry, this is all I can offer with my (limited) knowledge of FFmpeg. You could first encode to elementary streams (m2v, mp2) and then try tsmuxer like poisondeathray suggested in a earlier post.
Perhaps other people can help if you explain what your goal is with the final ts stream and why the specs need to be that strict. -
Hi all
I am trying to mux video and two audio streams into a transport stream video file.
How can i do it with AVANTI?
There is no problem with one audio stream but and i can't do it with 2 audio streams
I've got: video.m2v, audio1.mp2 and audio2.mp2. I don't need to reencode audio streams.
Thanks -
Avanti isn't the easiest app to do that. You need to do some command line work.
There's a item in the help at index "FFmpeg/Demux, Mux and Copy" named "How to set up complex muxing operations.".
If you set the video "Codec" field to "Copy Video" and press <F1> you easily get to that help section. -
It works fine. but i don't know how to get a ts file with VOD cablelabs specs. It shows too many errors in multiplexing buffer overflowed...
Avanti:
... pkts
I was trying to do it with obe-vod but it doesn't support MPEG2 codec
Thanks -
Can't be of help much on that! You can look here ...
http://www.pixeltools.com/tech_tip_cablelabs.html
There's a download of a zip with ini files that shows VBV buffer size and muxrate values for SD and HD. For SD, I had some success with "VBV buffer size" set to 112 and by adding -muxrate 9000k to the command line.
EDIT: You also need to enable the "Rewrite PTS" option.
Also keep in mind that your source m2v needs to satisfy certain criteria like SD bitrate 3.75 mbps and HD bitrate 19.0 mbps.
They seems to plan it for the future.I was trying to do it with obe-vod but it doesn't support MPEG2 codecLast edited by Chris K; 6th Jul 2011 at 08:56.
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 12:39 -
AVANTI (FFMPEG) Question
By erichollis in forum Video ConversionReplies: 1Last Post: 18th Aug 2011, 15:54 -
Avanti - FFmpeg verison
By ABBrittain in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2011, 04:01 -
I need a supported build of ffmpeg for Avanti 0.4.8
By flashandpan007 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 09:28 -
Conversion from Transport Stream
By mparter in forum Video ConversionReplies: 3Last Post: 7th Mar 2008, 14:02
