  1. I don't have this problem with other players, just MPC (MPC-HC 1.3.2121.0). No matter what type of media I'm playing, whether it's a video or an mp3 , the audio is always messed up. Listen to the samples , look at the waveforms ("GOOD" was recorded from BSPlayer) and tell me what you think of all that.
    Jun 2013
    Saint Louis, MO
    Download AC3Filter if you haven't already and install that. Have AC3Filter handle all your audio and open it up in the system tray while playing a file and adjust the audio down to 0 db. That fixed it for me. If you're having trouble, let me know.
  3. DECEASED
    Jun 2009
    Heaven
    https://forum.videohelp.com/members/201640-taptchan says:
    Last Activity: 6th Jun 2011 11:51 (GMT)
    Hope this helps
  4. Very late reply but was never really answered. I had the same problem only with MPC even the latest version.
    This is what you do :
    1 under view menu, open options
    2 go to audio swticher
    3 enable normalize and set boost to 0
    4 un-select "enable custom mapping"
    This solved my distortion issues.
  5. Originally Posted by dreamerm6 View Post
    I know this is an old thread but I just had to reply and thank you, this solved a problem I've been having since LAST YEAR. I wish I'd found this sooner.
