probably very obvious, but what is the shortcut keys to highlight items in a list but be able to skip certain files?
what i mean is, imagine you are looking in your external hard drive, there is a long list of say 500 files, you wanted to delete 20 files ( not all next to each other) if you press SHIFT + (?).. will that allow you to highlight certain files while being able to not nightlight others all at once?
sorry, hard to explain but a common task im sure,
thanks guys
Should be CTRL on a QWERTY keyboard to highlight/select individual items. (STRG on a German QWERTZ keyboard).
oh yeah i know about control, what i meant was...for example, there is a list of 40 movie files downwards. if i wanted to select them all i would press CTRL and arrow down to cover them all
what if i wanted to select say the 3rd, 7th, 11th, 19th and 26th file....so 5 files not in a row...how do i highlight those 5 files at once, without highlighting the files between? -
To select multiple files in a row it would be SHIFT-select. Use CTRL-select and click on your files one at a time, regardless of order.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Pioneer DV-610AV-K disc navigator shortcut?
By exatera in forum Newbie / General discussionsReplies: 0Last Post: 6th Apr 2011, 11:51 -
How to restore desktop shortcut arrows and folder/file icons.
By lelouch283 in forum ComputerReplies: 1Last Post: 6th Sep 2010, 22:24 -
Backing up blu-ray shortcut
By alucard2050 in forum Blu-ray RippingReplies: 4Last Post: 1st Dec 2009, 10:10 -
shortcut GfDA
By lordsmurf in forum FeedbackReplies: 2Last Post: 7th Dec 2008, 22:50 -
Shortcut for cutting overlay clips from to sources??
By Jensen in forum EditingReplies: 4Last Post: 22nd May 2008, 14:43
