got some mkvs, after moving from one HDD to another, I've noticed one of them was not ok, it skips like a 3 minutes, I would like to run a batch check or something on the hole library (mostly music videos).
the old hard drive was faulty, so I guess more than a vid is damaged.
Any help will be appreciated
if the files had been damaged on the old drive windows wouldn't have copied them to the new one. it would have stopped on crc errors. no way it would join files with missing pieces in the middle. just run error checking on the whole drive - right click on the drive/properties/tools.
of course some of them didn't copied, previous ram errors suggest than more videos could be damaged, that's why I ask, sorry I forgot that
you may use virtualdub program and use the "search video stream for errors"(have@the picture). Please up-2-date me with
the latest version features on mkv files.
remars:virtual dub is a good program for fast&simple, video trimmind|cropping edit, and allows you to make use of plugin`s.
external:More on plug`ins please read@http://superuser.com/questions/11383/what-are-the-best-virtualdub-addons/ -
Already tried it, I was unable to make it work properly, it's creating a tmp file for each space found in the filenames, so it creates like 3 to 7 files per video, result is, ffmpeg can't find the file...
Anybody had success with this???
tried it on debian box.
.::Edit::.
Using the scrip Bjs suggested works renaming files so they contain no spaces but underlines or something else
take in count FFMPEG must be set to './ffmpeg.exe', preferably in the same directory as media files, this, using cygwin.Last edited by bidomo; 7th Jun 2011 at 01:49. Reason: solved
Check DVD for errors
By Happichap in forum TestReplies: 1Last Post: 10th Mar 2011, 06:53 -
How to check the duration of multiple .mp4 videos?
By RiTu in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 15:50 -
How to check for encoding errors
By Dark Alpha in forum Video ConversionReplies: 5Last Post: 30th Jan 2010, 10:25 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
