Closed Thread
    Jun 2011
    London
    Hi
    I am trying to convert videos in some format into flv using ffmpeg. The converted video that is create is 0 kb. I need some help to get it working thanks.
    This is the code:
    <?Php
    function makeMultipleTwo ($value){
    $sType = gettype($value/2);
    if($sType == "integer"){
    return $value;
    } else {
    return ($value-1);
    $srcFile = "Videos/robot.avi";
    $destFile = "Videos/robot.flv";
    $ffmpegPath = "ffmpeg";
    $flvtool2Path = "flvtool2";
    $ffmpegObj = new ffmpeg_movie($srcFile);
    $srcWidth = makeMultipleTwo($ffmpegObj->getFrameWidth());
    $srcHeight = makeMultipleTwo($ffmpegObj->getFrameHeight());
    $srcFPS = $ffmpegObj->getFrameRate();
    $srcAB = intval($ffmpegObj->getAudioBitRate()/1000);
    $srcAR = $ffmpegObj->getAudioSampleRate();
    $command = $ffmpegPath . " -i " . $srcFile . " -ar " . $srcAR . " -ab " . $srcAB . " -f flv -s " . $srcWidth . "x" . $srcHeight . " " . $destFile . " | " . $flvtool2Path . " -U stdin " . $destFile;
    $convert = exec($command);
    if(!$convert){
    echo "FAILED!!!";
    I must say I do not have flvtools on my server but I guess it does not matter as flvtools is only used for getting meta data.
    Thanks.
    USA
    Tonybot, Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    Continue in: https://forum.videohelp.com/threads/335647-php-ffmpeg-video-conversion
    Moderator redwudz
