I can't play my camcorder (Canon HF R100) or bluray AVCHD video files smoothly.
I tried most of the programs/codecs in Windows 7 x64/XP SP3 with the latest driver
The only way I found is to reinstall the graphic driver without reboot then it plays great until I don't reboot or run any program that uses GPU.
I can play with my CPU (T7500) and Splash Pro without quality loss but it uses all of my CPU.
My graphic card is 8600M GT 256MB DDR2. Here's the information of the camcorder and bluray video files:
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 151 MiB
Duration : 1mn 20s
Overall bit rate : 15.8 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Duration : 1mn 19s
Bit rate : 14.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.240
Stream size : 142 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1mn 20s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -67ms
Stream size : 2.44 MiB (2%)After reinstalling graphic driver (smooth):General
Format : BDAV
File size : 14.4 GiB
Duration : 1h 15mn
Overall bit rate : 27.3 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=24
Codec ID : 27
Duration : 1h 15mn
Bit rate mode : Variable
Bit rate : 22.4 Mbps
Maximum bit rate : 33.0 Mbps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.360
Stream size : 11.8 GiB (82%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 15mn
Bit rate : 1 576 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Audio #2
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 1h 15mn
Bit rate : 2 304 Kbps
Bit depth : 24 bits
Stream size : 1.21 GiB (8%)
Anytime else (not smooth):
  Black and White TV Output From Nvidia Geforce 8600 GTSBy nicolasqueen in forum Media Center PC / MediaCentersReplies: 7Last Post: 24th Jan 2010, 18:40
  Nvidia 8600 GTS graphics card Insuficient power supply with Antec 500wBy Hogie in forum ComputerReplies: 4Last Post: 5th Jan 2009, 02:59
  Nvidia 8600 GTS graphics card Insuficient power supply with Antec 500wBy Hogie in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2009, 22:11
  New DGavcdecNV Decodes AVCHD via Nvidia CardBy Soopafresh in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 15:28
  Q: What rated power supply to use with nvidia 8600 GTSBy FulciLives in forum ComputerReplies: 19Last Post: 19th Nov 2007, 01:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
