Hi folks... I am going to be doing some traveling over the next year and I was wondering if there is such a thing as a multi standard portable digital TV.
Since every part of the world uses different digital TV standards I'm looking for one that at least has ATSC and DVB.
Is there such an animal?
Good idea, ... looking. Existing seem targeted at RV/camping.
http://lcdtvbuyingguide.com/hdtv/mobile-tv.html
http://www.google.com/search?hl=en&q=travel+DVB+LCD+TV&bav=on.2,or.r_gc.r_pw.&biw=981&...og&sa=N&tab=wi
http://www.overstock.com/Electronics/Envizen-7-inch-Portable-Digital-TV-DVD-Player/435...tml?rcmndsrc=2 Most are ATSC or DVB-T only. No luck.
Another possibility is a USB DTV tuner stick for a laptop, or several. One for each standard.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If you like edDV's idea. This TV tuner stick has a tuner capable of working with most terrestrial TV broadcast systems http://www.amazon.com/Diamond-TVW750USB-ATI-Theater-Tuner/dp/B002UOUQ08
Of course you will still need a good antenna, but you might need that for a portable TV as well. You will also need good TV software for the laptop, and will have to set it up again each time you change cities. -
It would have been helpful if you had filled in the computer details in your profile so we knew you were using a Mac. As far as I know, the Diamond TV Wonder 750 USB is the only TV tuner stick with a tuner capable of tuning DVB-T, ATSC, NTSC, SECAM, and PAL. You will have to buy more than one TV tuner stick to have the same ability with a Mac.
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Please recommend reliable Portable Digital TV
By V Bot in forum Portable VideoReplies: 2Last Post: 9th Oct 2011, 11:28 -
The least camcorder in the world!
By fairytale00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Jun 2010, 21:57 -
Western Digital Portable Hard Drive question..
By Soccerman77 in forum ComputerReplies: 1Last Post: 9th Feb 2008, 02:29 -
If I buy a 14 inch SDTV with a digital tuner, can i watch digital programs
By davidsama in forum DVB / IPTVReplies: 3Last Post: 6th Sep 2007, 10:25
