Hi..Many years ago I traveled round the South Pacific Islands and I had a movie camera with me... then a few years ago I decided to get my film taken converted onto a DVD but first I decided to buy a second hand projector so that I could mark each spool in order...Well I finally got a Sankyo Dualux 1000 H projector and it had with it some film spools and I unfortunately allowed these to become mixed up with my own spools...NOW?? finally I decided to try and sort these out...BUT...I have some problems ...I am presuming here that the projector when plugged in and switched to "Lamp" ..the lamp should go on unless it sees no film threaded ....Well theres no lamp light and I am unsure just how to thread the film...So I would be sincerely grateful if anybody can help me (1) in getting a manual download (2) or how to put in a new bulb and am I right in assuming that the only method to actually sort these spools out is play them in a projector ..(I did try and view the film by eyesight but found it impossible)
Any help on the above would be gratefully received ...Many Thanks MK
	*** Never mind, they are temporarily closed to due the death of the founder. Sorry to get your hopes up, but if the status of the site ever does change you can check back at this place.
 I cannot vouch for this place at all, but after doing some searching this is the only "looks legitimate" site I came across with the manual you want. The downside is it is actually the real manual (also they offer a repro) so you would have to purchase it. At any rate link below:
 http://www.craigcamera.com/ib_s.htm
 on that page scroll (or search) #SAN-058 and that will bring you to the repro ones with the original right above it
  Sankyo Dualux 1000 ProjectorBy grumpypaul in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2012, 14:01
  SUPER - DVD Conversion?By MVW in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2010, 16:02
  What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05
  SUPER - is it really super? (a behind-the-scenes look)By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 09:29
  using SUPER to convert a DVD to MP4By snafubaby in forum Video ConversionReplies: 1Last Post: 8th Aug 2007, 16:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
