Folks may do well to exclude Real Media Player option if installing the otherwise handy freeware SUPER v 2011 Build 48" from the publisher's site (eRightSoft.com). The RM extra installs a trojan type program in the autostart section of Windows' registry without your permission, causing the app to start each time Windows is booted. The registry key is located as follows:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run
Value Name is TkBellExe
Value Data: "C:\Program Files\Real\RealPlayer\Update\realsched.exe" -osboot
Djard
medfaith@yahoo.com -
AFAIK realsched, when installed with Real Player, is harmlesss. I have it running in my system and no issues whatsoever.
On the other hand, if you have more than one instance of realsched running - check your Task Manager - then you are quite likely to have a real Trojan installed and running.
On this system, realsched uses 0 cpu and 244k of memory. -
long ago i was a big-fan of super....but for the same reason as yours i dropped it out-of my choices.
MediaCoder is almost same as SUPER.
Try XMedia Recode (which is one the best and FREE too!) instead which gives you more flexibility. -
According to my hacker defense suite, ProtectX, the entry is identified as a "trojan." But even if it does not harm my system, the idea is offensive; besides, for SUPER to add the thing suggests it must do something... spyware?
For video conversion I use ConvertX, which is a truly a wonderfully super app; unfortunately it does not offer control over bitrate, etc. So Im thankful for the referral to XMediaCode.Djard
Freemake video converter is another very easy to use all-in-one converter. Does not support as many format as super though.
XMedia Recode has some nice features. Too bad it does not create IFO files when converting to DVD. I know video gurus tout apps like IFOEdit as capable of creating IFOs, but none of those wizards can communicate how it's done: I followed the steps of several IFOEdit "guides," but the IFOs never worked. If someone has personally created an IFO that does run a VOB, I'm hoping you'll share this apparently closely guarded secret.
Djard
medfaith@yahoo.com
Trojan Horse Downloader in Super???
By Anonymous4374945 in forum ComputerReplies: 13Last Post: 18th Aug 2012, 22:00 -
SUPER gives me a trojan (Generic!Artemis) on start-up
By Nintendo Fan in forum ComputerReplies: 11Last Post: 27th Jan 2009, 14:33 -
Does anyone still have the older build of SUPER?!
By Nintendo Fan in forum Video ConversionReplies: 11Last Post: 21st Jan 2009, 18:29 -
Super Build 35 - does deinterlacing work?
By dvdfever in forum Video ConversionReplies: 0Last Post: 7th Jan 2009, 03:22 -
is Erightsoft's SUPER a Trojan?
By mister_to_you in forum Video ConversionReplies: 4Last Post: 13th Jun 2008, 02:30
