Well, I created this mpg file and split it in half so it could be burned onto two 80-min CDs. The first half was burned perfectly. But Nero 5.5.4.0 says that the second part takes up 90 minutes and won't fit into the CD. But the second half is actually shorter than the first half and the file size is smaller too.
What's causing this problem? I have Windows XP.
Try loading the 2nd mpg into VCDImagerGUI and make a bin/cue and try burning it w/ cdrwin
You might want to try my response to this topic. Depending what you used to cut the file and the output type selected when you did the cut. This sometimes works using TMPGEnc:
http://forum.vcdhelp.com/viewtopic.php?t=83058&highlight=
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 16:28 -
Problem creating burnt-in subs for other chapters with AutoGK
By Squirrel448 in forum SubtitleReplies: 5Last Post: 3rd Jan 2011, 19:07 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 16:16 -
problem with fairuse wizard creating project
By Wizard23 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 15:30 -
problem creating my own component cables.
By nick101181 in forum Newbie / General discussionsReplies: 10Last Post: 2nd Oct 2007, 14:13
